Trailer Tongue Jack
Discussion in 'Miscellaneous Repairs & Maintenance' started by liv4mtns, May 1, 2010.
  1. Raycfe
    14,409
    1,074
    Try to find some metal bushings (power equipment shop?). And use a Grade 8 bolt with a matching lock nut.
  2. BigBaron
    4,583
    Jun 21, 2012
    I made mine using a 12" piece of allthread and used nuts to space the wheels out. It works fine. I don't have pics of it or I'd post them.
  3. speckhunter80
    4,782
    61
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    You can buy boat trailer tongue jacks rated for 1,000-1,500 pounds for $40-$90. Any of these will work on a camper trailer that has a tongue weight of only 200-400 pounds
  4. speckhunter80
    4,782
    61
    Jul 26, 2012
    etrailer sells three for less than $50
  5. CAMPERBOB
    CAMPERBOB New Member
    48
    Jun 13, 2014
    I ended up getting some 8" speed wheels (solid) with a 1/2" hub.
    Total cost about $20. Rolls much better now. I only use the wheels on concrete because of where I have to park the PUP, can't be done with the TV.
  6. MrBill12
    MrBill12 Member
    33
    19
    Nov 13, 2017
    Pensacola, FL
    I know this is a really OLD thread, but I decided to build this "fat tire" wheel jockey for my Aliner.
    Started with what I had on my Tongue Jack:
    Here are materials I purchased
    (itemized list under the photo)
    First, disassemble the original wheel from the Tongue Jack.
    Push the 10” Hex Bolt through the original wheel frame and one of the Tees. I inserted one of the washers between the wheel and the wheel frame.
    I discovered that the 10” Hex Bolt was about an inch too long and both DIY stores (Lowes and Home Depot) did not stock a 9” bolt, so I used 2 nylon spacers on each side.
    Here is the final product! I used a rubber bungee to hold the handle up for photo purposes, since Vanna White was too busy to model for me.
    A close-up of the Fat Tire Wheel Jockey!
    It works great, even on my soft, sandy Florida soil. Total cost around $50 and a LOT sturdier that the flimsy Chinese trailer dolly from Harbor Freight.
    Popiworks, Strawhouse and Ductape like this.
  7. nineoaks2004
    6,675
    2,610
    Graceville, Florida
    Looks good, should hold up for a long time. Thanks for sharing.
    MrBill12 likes this.
  8. Strawhouse
    Strawhouse Well-Known Member
    1,188
    343
    Oct 4, 2015
    Muskoka, Ontario
    Brilliant! Thanks for sharing!
