Trouble lowering roof, too much torque required to get it started
Discussion in 'Lift Systems' started by Kevinhawk, Jun 12, 2018.
  1. Kevinhawk
    Kevinhawk New Member
    May 8, 2018
    I've got an 04 Fleetwood and it raises up without a problem, no extra torque or tightness.
    But when I lower it that's another story. To get it started to lower it requires way too much torque on the hand crank. And as I'm lowering it, it does not feel smooth at all. Has a little tight spot then feels normal, and it occurs when hand crank is in thebsamt spot each time.
    As it lowers it gets easier to crank.
    I lubed up the chain, and check the wiffle and it looked good.
    What am I failing to check which is causing this?
    Thanks!
  2. Raycfe
    13,746
    861
    Sounds like to me that the crank driveshaft is hang up. When you crank to lower it should unthread and let the clutch slip.
  3. Kevinhawk
    May 8, 2018
    What could be the issue? Maybe gunked up?
  4. Raycfe
    13,746
    861
    Or the threads are bad.
  5. jnc
  6. Kevinhawk
    May 8, 2018
    Thank you!
