Velcro around door peeling away
Discussion in 'Miscellaneous Repairs & Maintenance' started by Hjoybella, Jul 12, 2018.
  1. Hjoybella
    Hjoybella New Member
    Jul 8, 2018
    The Velcro around the door of our pop up is peeling away from the frame. The Velcro itself appears to be strong and in good condition, the glue backing just isn’t holding it is place.
    Can anyone suggest a good strong glue to use to reattach the Velcro?
    Thanks.
  2. Orchid
    Orchid Sharp Shootin' Grandma
    4,748
    1,241
    May 8, 2011
    Florida by way of WV and MD
    I used Crazy Glue, from the Dollar Tree, on mine. Has held up fine.
  3. Sjm9911
    2,364
    901
    I'm just going to get some new Velcro for mine. Ca, sounds like a good alternative.
  4. Sjm9911
    2,364
    901
    Sorry just thought of this, if cold weather camping, ca might not hold up well it gets brittle. We used to put our model train buildings in the freezer to take them apart. So is good in warmer climates, in the cold might not be so good.
  5. jnc
    3,896
    1,139
    Oct 1, 2014
    South Central New Hampshire
    I used Hot Glue.
    Sjm9911 and nineoaks2004 like this.
