Water hose question
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by eagle, Dec 4, 2017.
  1. eagle
    eagle Member
    48
    May 2, 2017
    Hi, all.
    This past weekend we had a great time at Carolina Beach State Park in NC. We were at a site that had full connections, and as we were cleaning up, one of the ends of our white water hose came into contact with the sewer drain inlet.
    Does this mean that our white hose is now contaminated? Or, can it be disinfected somehow?
    Thanks.
  2. JPBar
    JPBar Well-Known Member
    1,459
    317
    Sep 22, 2016
    Texas
    Would think not unless it fell in the sewer hole. You could always pour some bleach on the end that came in contact with the sewer outlet.
  3. chambo
    chambo Active Member
    297
    72
    Apr 27, 2015
    Southern California
    For me it would depend on if the wife saw it. :)
    It comes down to your comfort level and the degree to which it made contact. If contact was only minor and the hose did not appear to be soiled then giving it a soak in a bleach solution should do the trick. I believe it's a quarter cup of bleach to a gallon of water, but I would google that. Would cutting off the last foot of hose and attaching a new fitting do the trick?
  4. xxxapache
    1,895
    232
    Squirt a little bleach solution in it and roll on.
    Every spring, I put some bleach in my hoses and connect the ends. I roll them over a time or two and then let them sit a few hours before rinsing them out.
    Fless likes this.
  5. crackerJack
    crackerJack Active Member
    828
    97
    Jan 6, 2014
    Scottsville, KY
    X4 in the bleach. ^^
  6. nineoaks2004
    2,601
    181
    Graceville, Florida
    X2 Bleach will surely dis-infect it.
  7. Snow
    8,548
    244
    Bleach, peroxide or isopropyl alcohol will do the job. ..
  8. Fixitup
    Fixitup Active Member
    167
    40
    Jun 7, 2016
    What doesnt kill us......only makes us stronger. Little bleach and your good!
