What? Stabilizers down after the top is up?
Discussion in 'Stabilizing Your Camper' started by MyName, Apr 8, 2018.
  1. Sjm9911
    2,327
    886
    Lol, i found all my paperwork in my camper, including the brochures, way cool.
    As for the stabs, the colman lift system is conected to the frame, if you over crank a stabilizer it can cause resistance when lifting the top. This is not to say it will, but can. So why take a chance? You are of course good to do what you want, but for me , i dont want to maybe have to do a repair. I have enough stuff to do!
  2. GreyFox
    GreyFox Active Member
    415
    148
    Oct 10, 2018
    S Ontario
    Surprising what's available online these days if you just take the time to look. [;)]
  3. BedHead
    BedHead Member
    33
    Feb 20, 2019
    There are probably a lot of things in the owners manual we don’t remember. We bought it in 2008. Maybe we read that and then forgot? I dunno. My point is, reading this thread on here was an eye opener for me and I learned something and now I am smarter than I was before I read it. I’ve camped in pop ups all my life and set up probably thousands of times and always done it by putting the stabilizers down first. Now I know better, at least for the one we have now.
  4. bob414
    bob414 New Member
    Jan 31, 2019
    Stabilizing jacks are not designed for leveling or changing tires? But they are mounted on the frame. If I can't use the frame to raise the camper, where do I place the jack for changing the tire. I read somewhere do not use axle because it could be bent.
    I positioned my jack on the frame, at the point just behind the leaf spring joint, to repack wheel bearings. However, stabilizing jacks are not near the axle and could cause some twisting, but the frame should be able to handle that without permanent damage, unless stored that way for long period. Where is my thoughts going wrong?
    Bob
  5. GreyFox
    415
    148
    Oct 10, 2018
    S Ontario
    Do what your owner's manual says.
    gladecreekwy likes this.
  6. theseus
    theseus Centerville, OH
    2,624
    290
    Feb 6, 2007
    Centerville, OH
    Use the axle. If the weight of the camper was going to bend the axle, it would do it before you jack it up.
    I put the jack on the point where the axle and springs are bound together.
  7. tfischer
    tfischer Well-Known Member
    3,092
    634
    May 21, 2014
    I can guarantee you page 29 of my manual doesn't say that. And I can also guarantee you a different page it says to put the stabs DOWN first.
    Hint: Not everyone here has a Coleman/Fleetwood. And not all brands have the same instructions.
  8. GreyFox
    415
    148
    Oct 10, 2018
    S Ontario
    What has my reply which was clearly addressed to Bedhead about her Fleetwood popup got to do with you and your Palomino?? [?:~{]
  9. mstrbill
    mstrbill Active Member
    659
    135
    Mar 17, 2013
    Austin , Texas
    YMMV, you may find that using the axle pushes the wheel too far up in the wheel well to get the wheel off. My Niagara is like this. My Bayport was also like that, but I put a new overslung 3500lb axle on it which fixed the problem.
