What type of rivit help needed. Coleman/Fleetwood back panel
Discussion in 'Miscellaneous Repairs & Maintenance' started by MNHep, Jul 4, 2018.
  1. MNHep
    MNHep New Member
    Apr 10, 2018
    Minneapolis, MN
    We are brand new pop up camper owners. This spring we bought a 2005 Fleetwood Americana Valor (I think same as Coleman Mesa?). Before we were able to use it, the life system broke. After watching the Carolinas Campers on youtube, we figured it out and got the lift system fixed. Thank you to Pop Up Parts and Carolina Campers! Our dilemma is what type of rivits to use to put the back panel back on. The video we saw said to use panel or split rivits. They don't look right to my husband. What kind of specific rivits have others used when attaching the back panel? We are anxious to get camping in our new to us camper.
  2. Raycfe
    14,007
    951
    I used stainless steel screws to replace the rivets.
  3. wayoutwest
    wayoutwest Member
    101
    Aug 23, 2013
    Oregon
    I just recently replaced some rivets on my old Coleman Columbia. A rear trim piece as the the old stainless steel screws kept backing out. I simply used a drill bit to see how big the original hole was, went to the hardware store to find pop rivets with that same shaft diameter, about 1/4"-3/8" long and used a hand rivet tool from HF. The HF kit come with 100 ast rivets (25 in 4 different sizes) but the size I needed wasn't in it. I will have to re-rivet how who front panel back on as I pulled it to grease up my lift system also.
    I don't think you will have to match the OEM sizes as its doubtful it will matter to anyone but you.
  4. Mogimus
    Mogimus Active Member
    444
    64
    Apr 29, 2015
    Rancho Cucamonga, CA
    I believe the rivets that come with the trailer are 3/16" stainless steel tri-fold rivets. If you have a pneumatic rivet gun, i'd use the same. When I re-installed the rear wall on mine, I used standard 3/16" aluminum rivets with a hand rivet tool and so far, haven't seen them loosen up or pop out.
  5. Fless
    Fless Active Member
    891
    162
    Aug 14, 2012
    Colorful Colorado - the Centennial State
    @MNHep,
    If you're going to re-rivet into ABS or other brittle material, you may want to use some of these expanding rivets: https://www.mcmaster.com/#catalog/123/3339/=1affgj9 and scroll down to the "Wide-Grip Blind Rivets for Soft Materials" section. I used the aluminum ones numbered 97545A080 when I re-did some attachments (e.g., marker lights) to the ABS on my '02 Cheyenne. You may need a different grip range. These are also called "exploding" "expanding" or "tri-fold" pop-rivets.
    _
  6. GrueMaster
    GrueMaster Active Member
    147
    41
    May 22, 2013
    Saint Helens, Oregon
    I had an issue with my Coleman/Fleetwood Timberlake where the rivit holes either cracked or the rivits popped out of the ABS. To fix it, I bought a 6' length of aluminum flat metal from Ace Hardware, cut to length, and glued it to the inside of the ABS. Then used self tapping metal screws to screw it in place, with the aluminum strip acting to sandwich the ABS. Much stronger than the original, and a very cheap (~$10 US) fix.
    Unfortunately, the ABS covers are all but destroyed now. Replacing them with diamond plate this year. See my other post in the Garage.
