Wheels up
Discussion in 'Tires / Brakes / Bearings / Axles' started by KennyMiller, Jul 10, 2018.
  1. KennyMiller
    KennyMiller New Member
    Jun 12, 2018
    Hey everyone, I have a 74 Starcraft Starmaster. I tried the o get the wheels off, but broke my socket wrench in the process. Would those bolts be reverse threaded?
    Also, if I get Keva he wheels off (repainting), do I need to repack?
    Thanks!
  2. nineoaks2004
    4,314
    1,201
    Graceville, Florida
    If you are taking the hubs off, I would re-pack. Make sure you get new rear seals just in case.The worst part is over anyway (taking the hubs off) As far as being reverse thread I cannot say, but if so it seems like something rare. Did you use a heavy duty ratchet? Or a cheap one ? You might want to spray the lug nuts with a penetrating oil and let them sit for awhile. Good Luck with the project.
  3. Sjm9911
    757
    263
    Penetrating oil and let then sit for a day or two
    J Starsky likes this.
  4. KennyMiller
    Jun 12, 2018
    Ok, thank you!
  5. J Starsky
    J Starsky Active Member
    358
    186
    Aug 3, 2017
    East Central MN
    A little heat never hurts either. I use an electric impact gun and I use that more than my air ratchets.
  6. KennyMiller
    Jun 12, 2018
    I got one off, had to use a hammer on the star wrench to get them moving. I’m sure the other will require the same treatment. Thanks!
  7. Sjm9911
    757
    263
    Let the oil do the work, I couldn't budge mine they were so rusted, 2 days later they spun right off.
  8. Raycfe
    12,834
    493
    If they are just hubs (no brakes) you will have to soak the backside of the hub as well. I have seen the lug bolts stick out the backside and rust.
