When closing the roof, do you undo the zippers?
Discussion in 'General Camper Setup / Take Down' started by Chrismtl, Jul 9, 2019.
Do you unzip the canvas when closing up shop?
  1. Yes, every time.
    12 vote(s)
    50.0%
  2. No.. why waste your time?!
    11 vote(s)
    45.8%
  3. Depends on how I feel.
    1 vote(s)
    4.2%
  1. tombiasi
    5,089
    838
    You are welcome.
  2. PopUpSteve
    PopUpSteve Administrator
    18,563
    1,410
    Dec 22, 2002
    Malvern, PA
    Nope, Don't see the benefit. Perhaps it depends on the manufacturer and the age of the camper since the material can shrink.
    J Starsky and Chrismtl like this.
  3. J Starsky
    J Starsky Well-Known Member
    655
    424
    Aug 3, 2017
    East Central MN
    Age certainly drives my choice
    Chrismtl likes this.
  4. MileHigh
    MileHigh Active Member
    431
    42
    Jul 18, 2012
    Denver
    I unzip the bunkend windows about 1/2 way down as it seems to let some air out and makes it easier to collapse the roof.
  5. bheff
    bheff Active Member
    417
    140
    Feb 24, 2011
    NW Arkansas
    Your age or the age of the camper?[:D][LOL]
  6. J Starsky
    655
    424
    Aug 3, 2017
    East Central MN
    BOTH!!!
  7. benandbobbi
    benandbobbi Member
    162
    Dec 18, 2012
    my canvas must be way different. the only thing to unzip on my bunk ends are the windows which are still attached at the bottom. Unzipping these only causes more clumps of material. i lay the end canvas in on the mattress kinda folded like wrapping a Christmas present. As far as trapped air, my beds are slid in and the door is wide open before i start lowering and tucking. Maybe i just don't understand the question.
  8. Chrismtl
    Chrismtl Member
    135
    23
    Jun 14, 2014
    Pincourt - Quebec - Canada
    Most PUPs I've seen (actually, all that I've seen.. doesn't mean it's only like this) have zippers in the area behind the lift posts, that attach the bunk it the sidewall.
    soft 17 likes this.
  9. Dingit
    Dingit Well-Known Member
    755
    324
    Mar 8, 2017
    I've never thought to do it and don't even know if there are zippers there. Hmmm.
  10. Chrismtl
    Chrismtl Member
    135
    23
    Jun 14, 2014
    **Update** This past weekend I went out. I closed the trailer pre-trip with the zippers done up, set up and I find it is just one less thing to have to do. To popupsteve's point, I have noticed that they shrunk over time, and it was difficult/tight while zipping them, so I have less concern like this. I will continue not unzipping them! Thank you for all the feedback!
  11. Dingit
    755
    324
    Mar 8, 2017
    I looked at my zippers and they zip from the top to the bottom--which means they can't be reached form the ground. I was interested in seeing if partial unzipping would help with a spot we have that doesn't fold nicely, but that's not gonna happen!
    I bet you'll enjoy not doing it!!
  12. silvermickey2002
    4,588
    405
    Sep 11, 2008
    Morris County, NJ
    We have never unzipped anything when closing up. We see it this way, if it's pouring outside rain can get in. When setting up in the rain then it can get inside. We have never had an issue not unzipping when closing up. Everything folds up just fine and roof closes with no issues.
  13. Fil_Kay
    Fil_Kay New Member
    Jun 23, 2019
    Atlantic Canada
    This is my first PUp, but I've yet to do try unzipping when packing up. I was actually looking at the zippers the other day though, although I mostly assumed they were for ease of assembly rather than for regular unzipping.
    With that, my bunk ends are stowed and the upper half of the door is up before the roof comes down, so there's no concern with trapped air. So far, the canvas on the bunk ends has folded reasonably neatly while bringing the roof down, but we bring it down slowly and check the fold of the canvas a few times on the way down (about halfway down, again about 3/4 down, and finally about 4" from closed to tuck the edges of the side panel up under the roof). We fold the side panels in half, and the bunk ends get folded towards the middle as much as possible (like wrapping a gift).
    Having said all that, we just placed an order for a new canvas, so we may consider unzipping it when stowing the trailer (providing it's not raining); if it's raining when we stow it, then we'll have to pop it up the first clear day to let it air out anyway, so we can unzip it at that point. However, I'd probably unzip it all the way, rather than the 3/4 of the way recommended in previous posts; the canvas might stretch more fully zipped, but I feel that the seams/zipper are less likely to get damaged by either having the tension spread across the entire length (if zipped), or by separating both pieces entirely.
