Whistling/Shreiking heater
Discussion in 'Heating / Cooling Systems' started by Snowman, Oct 7, 2018.
  1. Snowman
    Snowman Member
    123
    Jul 12, 2017
    Boulder, CO
    Hey Folks,
    Just got back from a campout today with our '98 Santa Fe and it was cold and rainy most of the weekend. Consequently, the heater was on overnight and it wasn't exactly quiet. When it would cycle on, the heater would make a whistling sort of sound which would last several minutes into the cycle before calming down. After the cycle ended the heater would turn on again a while later when Tstat called for heat and it would again get noisy. Any thoughts what this could be? I appreciate any help that you can provide.
    Thanks!
  2. Raycfe
    14,009
    951
    Blower motor bushing/bearings dry. Sometimes just a little oil on the shaft next to the bushings and move the shaft in and out will do the trick.
  3. Snowman
    Snowman Member
    123
    Jul 12, 2017
    Boulder, CO
    Great, thanks! Is there a manual or something online that will show me where to find the shaft or bushings/bearings?
    Thanks!
  4. joet
    3,728
    567
    The bushings/bearings are behind the blower wheel. If you cant get to the bushings, try spraying PB Blaster on the shaft
