wiffle tree lube
Discussion in 'Lift Systems' started by peter moyes, Jan 10, 2019.
  1. peter moyes
    peter moyes Active Member
    126
    28
    Feb 6, 2018
    i have a 2000 sedona ,,apart from the wheel bearings ,what else needs lube or grease? how do i lubricate the lift gears etc .and what else needs lube ?thanks ,and happy new year to my pop up pals
  2. Halford
    Halford Well-Known Member
    3,442
    440
    Sep 28, 2011
    Santa Clarita, California
    whiffletree can use same grease for your wheel bearings.
  3. GreyFox
    GreyFox Active Member
    242
    92
    Oct 10, 2018
    S Ontario
    With the roof in the lowered position remove the wiffle tree cover plate ...
    https://photos.google.com/share/AF1...?key=Y0tiYWFzQl8xdGRCRmwwOV90TXBtYlpOZHdRc3VB
    Don't be surprised to find a large amount of accumulated dirt / sand mixed in with old grease. Clean it out as best you can and replace the grease with a copious quantity of bearing grease.
    The lift system cables should be lubricated with silicone spray at all the points where they run over the plastic wheel guides. Protect the tenting from over spray with an old cloth, etc, otherwise you'll damage the Sunbrella.
    PopUpSteve likes this.
  4. peter moyes
    126
    28
    Feb 6, 2018
    thank you so much for the info ,another great reason to add this site
