Winterizing Clipper
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by Whopper14, Oct 10, 2017.
  1. Whopper14
    Whopper14 New Member
    Jun 20, 2017
    Holland Mi
    I plan on blowing out lines and pouring some RV antifreeze down the drain. I am not planning on filling system with antifreeze. PUP will be stored inside in non-heated facility. I plan on closing off by-pass valves for water heater. My Clipper does not have head or shower. It does have outside shower which I will blow out. It is a mistake to not fill all lines with antifreeze?
  2. giadiep
    giadiep Active Member
    Sep 5, 2015
    Syracuse, NY
    I would fill the lines with RV antifreeze just to be safe. It is not really that expensive and does not use much. Also, it is easy to flush out next spring.
