12v adapter from light?
Kasey Redrum
Oct 17, 2019
46
Is there an adapter that would go from the 1/4in plug on the ceiling light to a standard 12v plug. I think they call this the bunk light?
Rusty2192
1,193
Kentucky
Just a 1/4” mono plug, 12v outlet, and some wire. You would just need to be careful what you plugged into it so that you didn’t draw too much current. Just make sure you have the right fuse for that circuit since it should be sized for the wiring in the walls and ceiling.
GreyFox
2,447
S Ontario
Make your own - wire a 1/4" mono plug like this ...
https://www.amazon.com/Switchcraft-280-4-Inch-Mono-Mount/dp/B00721DN40/ref=sr_1_9?keywords=1/4"+mono+plug&qid=1571920653&sr=8-9
... to a female 12 volt cigarette lighter receptacle like this ...
https://www.amazon.com/Cigarette-Terminal-Accessory-Inflator-ZHSMS/dp/B07DH8D4FR/ref=sr_1_fkmr2_2?keywords=1/4"+mono+plug+to+cigarette+lighter+receptacle&qid=1571920813&sr=8-2-fkmr2
Tip is positive, sleeve is negative.
MNTCamper
1,342
MN
Depending upon your needs for a regular 12V plug in receptacle, you may just simply want to add several to the camper. There are a few threads on this and it is quite easy to do. I have one on each end of my camper, along with 12V powered USB plugs.
domptg
New Member
Aug 20, 2022
I have 1/4'' stereo plug. Tip is positive and ring and sleeve negative together to female 12 volt cigarette lighter receptacle Is this going to work ?
