1993 Coleman Pioneer Sedona
Sjm9911
13,640
I would buy the assembly, but use the same drums. After you add up the money for the parts, it will not cost a lot more.
toucan
196
Western Oregon
I had that thought. Whats more, after I posted I looked up the price of Dexter hubs. $166 apiece! I will also have to wire in a 7 pin connector to the trailer, but thats not too much. For some reason this sled had brakes, no brakes and a 4 pin flat connector.
toucan
196
Western Oregon
Sagging bed fixed...for a time anyway.
Moved on to replacing canvas retainer around the doorframe. That sucked! For some reason I imagined the new plastic strip would have the rivet holes pre drilled. Negative. It was a pain to properly align it and drill new holes.
samh
Campin'
Jan 23, 2015
438
Bozeman, MT
Does your canvas have a bit of cordage that wraps from one side of the bed, under the slide-out, over to the other side to attach over there? The little "gun scabbard" bits might be for that. A piece of stretchy cordage will help keep the canvas pulled down and under the slide-out to keep it from blowing upwards and allowing moisture in on the bed.
toucan
196
Western Oregon
Yeah it has the usual bungee cord setup, although at this point it is parachute cord having been changed out by the PO. I asked on facebook and the consensus id those flaps fold up under the bed slides to "keep insects out". The manual confirms this.
toucan
196
Western Oregon
Can someone lay out the part numbers for a complete bearing and seal replacement? 2000 lb(i think) axle. Dexter 8-257 hubs. Its about clear as mud which bearings I need as the inner and outer are different I believe.
Outer bearing?
Seal?
Unsure which other bearing to buy, or are the inner and outer the same one?
ken1207
101
The part numbers you have are correct. The outer and inner bearings appear to be the same as well. Good luck
toucan
196
Western Oregon
Many small tasks achieved lately.
20230524_182129.jpg New lift trim x4.
Screen door canvas keeper done on both sides of door frame.
20230530_185908.jpg Coleman koozies in the house.
20230601_174311.jpg Door bumper thingies re-attached. No I didnt spring for the white rivets.
20230601_194038.jpg New electric brakes received.
Stepper door is all painted and ready for install.
toucan
196
Western Oregon
Got my hand painted Coleman emblem installed over the old outside 110 outlet. It was here some poor planning came back to bite me. Both the emblem on the right side of the door, and the dual 12v/usb charger on the left were installed too close to the door. So when its closed, the door edge is going to partly cover up both. I did some quick measurements and I don't think it's going to cause any problems other than obscuring the emblem a little. The door should still close properly.
Sjm9911
13,640
Good idea on the outside dc outlet. I need to do that. And watch that alien, hes getting too excited. Dont want to bring him across state lines and introduce him to another eccosystem.
toucan
196
Western Oregon
Moving ever closer to launch. Got the stepper door reinstalled, although I caulked the edges and did a lousy job of it. Oh well, if it bothers me too much I can peel it off and do it over. New brakes installed and tested for voltage. Ran new wire to them from the frame. Old wire was well, old. Torn and Frayed as the Stones might say. Put new Timken bearings in the hubs. The old were Chinese bearings and a couple were a little sloppy. I repacked them and put them in a ziplock for spares along with the new races. Old races looked fine. Now just waiting on grease seals to finish that job up. I had a hell of a time finding the right seals, but I think I have the right ones on the way.
Installed breakaway switch on the tongue, and ordered new safety chains and scissor-style stabilizers. The old Atwood ones are junk. Put my Primus IQ brake controller in my truck in a somewhat suspect install, but it works for now. Added a new 7 pin cord to the trailer. Today I continued cleaning the decal residue of the sidewalls with mineral spirits and a plastic razorblade in preparation for painting.
A couple small issues remain. Each taillight assembly has one broken tab where the lenses mount, but I think I can fix that with some small screws. The most concerning thing is that the curbside of the roof is an inch to an inch and a half higher than the roadside. Have any advise on tightening(or loosening) the lift cables anyone?
The end is in sight!
20230604_155603.jpg 20230608_172719.jpg 20230609_165736.jpg 20230609_165758.jpg 20230609_170024.jpg 20230610_091306.jpg 20230610_105010.jpg 20230610_105016.jpg
Sjm9911
13,640
You can check the manual, I think, there are two ways for ajustment, 1 is maybe at the top of the lift poles, thier may be diffrent positions to conect the screw at that point ( ita in the manual I think) the other would be to ajust the cable in the wiffle tree.
Apr 7, 2023
30
Peoria, Arizona
Real progress being made now! Might be able to camp Labor Day instead of New Years!
I love the knotty pine! I'm new to the group and just finding my way around. Did you use tongue and groove? We are updating our 1998 Utah and I want a cabin theme, and this fits perfectly! Thank you for posting such great pictures.
Leeann
Latest posts
