1998 Starcraft Spacemaster water tank drain
baileyc
New Member
Nov 1, 2020
Can anyone tell me where the drain for the water storage tank is on a 1998 Starcraft Spacemaster. I crawled under today and I swear I can't find it:-(
Snow
11,980
If the water tank hangs below the floor, the drain will be located on the tank, if it's a tank that sits inside the trailer, there should be a hose (might be very short) that runs through the floor, drain will be somewhere on that hose.. it could the original drain broke and previous owner use something else..
BillyMc
2,466
On our 97 Starmaster it's behind the driver's side tire on the end of a line, It's a "T" handle that you pull to open and push to close. The line is about the size of my pinky finger so it takes a while to drain a full tank.
Andy G.
Sep 2, 2017
88
WI
On my 1992 starcraft, the water tank is under the bench seat. The drain for that is on the side of the tank near the bottom, just above the floor. Turn the lever, and it drains straight down through the floor.
baileyc
New Member
Nov 1, 2020
Thank you! Found it! It was the passengers side, but it was in fact a tiny T handle. It just happened to be on the side opposite of where I crawled under the camper the other day.
Michael J
117
Hey does your Starmaster have the shower in it?
BillyMc
2,466
Do you still have it? Looking for pictures of the plumbing for the shower
No, we sold it last year. It had a 90 off the drain pan, a vent on the exterior wall, a pee trap, and a down pipe. When we used it I took the large cap off our 25 gallon tote and parked the opening under the down pipe.
Michael J
117
Did it look like this?
