A heat pump is an A/C with a reversing valve that instead of pulling heat out of the living space it pulls heat out of the outside air.The heat strip I had wasn't worth it. Even says more of a warmer then heater. I found that it was colder with the fan on then any heat output it had. Some like them, I think it was a waste. No idea what a heat pump is. So, can't help there.
Any idea how many btu's that is? I don't see it anywhere.Get the 20$ space heater and store it somewhere you dont usally access, and if you ever need it thank me later. Saved my butt a few times. Lol. And with the TT, heated the whole rig up in 28 degree weather. Not so much in the pup, but it puts out some heat.
My Palomino came "A/C ready" which meant a 20A breaker was in place and a wire running to a box under the kitchenette which had a blank plate on it with a sticker that said something like "A/C rough-in".
I'm not sure if the practice was to hardwire the A/C to that box, or install an outlet. If I had a choice I'd put in an outlet/plug if nothing else to use for diagnostics.
Since I have no plans on installing a roof A/C, I put a 20A outlet there and use it to plug in our portable A/C we sometimes bring along.
That is exactly what my unit has. The cord is long enough to leave it plugged in when rear king bed is stowed.Not sure on your camper. Mine was diffrent. I am sure you can maybe expoxy up some industral velcro. No holes and should be more then strong enough to hold a cord. Especially since most of the weight will be held by the wire mold. Plus it will keep it tidy
Most just dropped down from the celling. Yea, you have to remember to remove the wires and tie them up. Where is the factory blank in relation to the ac? I would think that would be the spot its ment to be in? In my colman it was behind the dinnet. I asume that was on purpose so when you broke down the table you saw the wire. But thats only a guess.
Well to be fair they also added the bracing to the roof. More than Coleman did.A/C "ready" meant a 20amp breaker and about 1' of wire into the blank with wire nuts on the lines.... kinda funny.
My "ready" box was at least maybe 4-5 feet, as the wire runs, from the converter. So I guess I got a bonus lol.
