2WD with auto locking differential?
kudzu
Gold Supporting Member
Oct 20, 2014
635
Knee deep in kudzu
Have started the search for my next TV. My Chevy Express is AWD. We don’t do real off-roading. We have had enough experience with snow & rough dirt roads to be glad for the added traction of AWD. The newer Transit vans offer an automatic, on-demand AWD system that seems much more complex than my current van. In my mind that means more likelihood of problems & more expense. Thus I am not enthusiastic over that.
Am looking at maybe a 2WD van or truck but I’ve had FWD or AWD for so long that I’m wary of returning to RWD. Am thinking of going with 2WD and auto locking differential. Does anyone have experience or knowledge they would like to share in that type of system?
xxxapache
4,555
I have an electronic locking rear end in one of my trucks. It works great if I get in a spot where one wheel spins. I often use it instead of putting the truck in 4WD.
Raycfe
Waterford Ct.
18,435
I never got stuck with a standard shift 2 wd ranger pickup. If I ever bought a new truck I would go for two wheel drive. Less money, less repairs, easy to get into
NMroamer
1,078
Albuquerque NM
I have had a couple of trucks with limited slip diffs. I think that is what you mean. They work great except on ice and where you are at a slight tilt left or right. You will end up in the ditch. Are prone to sliding sideways. A part-time four-wheel drive would work better.
Was in the mountains a couple of weeks ago with about six inches of melting snow on the roads. In four-wheel drive a little sideways slide was no problem with a little gas and the front wheels to pull me out.
Sjm9911
12,447
Hard question. When towing I only used 4 wd once. When in a torrential downpour over a bridge and people were spinning off everywhere. My camper hydroplained. Other then that, I have never needed it towing. Driving, I need 4 wd or all wd. Front wheel drive is ok, but rear wheel drive in snow and such is bad. I have to drive in bad weather. If you dont maybe its an option. For me it isnt.
xxxapache
4,555
I have a two wheel drive pickup. I only have it because it's been in the family 45 years. It's always been a fair weather pavement princess. We have towed a lot of campers with it, but are careful. The slightest moisture on a grassy incline and you are spinning. There's now way I would buy another 2WD pickup. My everyday truck is 4WD. I couldn't imagine life without it.
DanR
Aug 25, 2022
36
I’m a firm believer in have it and not need it over need it and not have it. I enjoy exploring dirt/sand roads too much to not have at least all wheel drive.
LilRed
1,197
Long Island NY
Had an old 90’s s10 Blazer with an Eaton locker on the rear differential, and 4x4 on the floor. Did great in snow even without engaging the 4x4. If one wheel slipped, the locker would bite and engage both wheels. While torque was on, it would stay locked up until I let off the gas, then go back to standard rear differential.
My Durango is some sort that electronic awd and miss the grip of a forced 4x4, but admittedly have zero issues with slipping or steering spin/pull in snow, and I don’t have to think to shift anything.
kudzu
Oct 20, 2014
635
Knee deep in kudzu
Thanks, all, for the input. Y'all are reminding me why I wanted an AWD van instead of just RWD. That is a decision I've not regretted one bit.
Except they offer that with electronic (Ford) or automatic (Chevy) locking rear. Meaning when in use it is full locking, not just the limited slip. Nonetheless, it is still RWD, not AWD or 4WD.
Yeah, that is what makes me hesitant. With FWD and AWD I've done well in wet, snow, and managed to make it home safe in ice. (I really try to avoid ice.) Have ended up in some spots towing the trailers where I was very glad for the AWD. Getting a RWD vehicle stuck is less likely with the electronic locking rear. However, sliding on slick roads is more dangerous and I encounter that a lot more often.
Grandpa Don
1,886
Southern California
I had a 2007 Ford Ranger with 2WD. Then one day I got it stuck in loose desert sand. I was able to get it out okay within a couple of minutes. But it scared me. So I ordered and installed a limited-slip differential for it. I had the Ford garage install it on a Wednesday. The truck was then stolen on the following Saturday and totaled while trying to outrun a police car. I never even had the chance to use it. Fortunately, my insurance helped to buy another Ford Ranger for me. This time it was a 2010 model with 4wd and a bigger engine. I was so thankful I had it when I went camping two years ago with my son in the high Sierra mountains. We go caught in a snow storm. Before we could get out, there was a foot of snow on the ground. My Ranger had no trouble pulling my pup out of a boondocking campsite through a foot of snow. And it was slightly uphill most of the way. I doubt that my 2007 Ranger with the Limited-slip could have done that. Driving in snow does not worry me any longer.
