Aframe corner separation
blewwis
New Member
May 22, 2023
Hello all,
I'm looking for some recommendations on mending my '03 Chalet Arrowhead. The cover blew off and then froze to the ground over the winter (I'm in NH). I've now got some water damage inside and this front corner is separating. I'm not sure what to do 😩. Please help!
Brianna
PopUpSteve
Administrator
Staff member
Gold Supporting Member
Dec 22, 2002
22,079
Southeastern PA
When you say "the cover blew off", do you mean a canvas (or other material) cover which covered the whole camper, or the roof?
blewwis
New Member
May 22, 2023
Just the canvas winter cover. If the roof blew off that would be a whole different problem! 😋
PopUpSteve
Administrator
Staff member
Dec 22, 2002
22,079
Southeastern PA
I'm sure one of our A-Frame members will chime-in with a more detailed plan for you but from your photo and short description, I would think you're looking at taking that end off so you can replace any water damaged wood.
Dnodoz
157
if you are not skilled to disassemble and repair you might call Midwest A-Frame Repair and Service. John Pheil has a long history with repair of Aframe trailers. Just Google for the number.
Econ
1,806
Deep South
I would be extremely careful about getting within 18" of that corner. IF, this was an Aliner, There is a coiled spring with a leg mounted in that corner that assists in raising the roof. I've seen photos of them kick thru the rear metal paneling. Dnodoz give good advise.
trikte
New Member
Jun 14, 2020
Hello !
I just did mine , look how bad it was. I added an 1/8 thick aluminium sheet
I had to replace both side walls as they were rotten ( IMG 7823 )
Overall it took 40-50 hours for 400 $ ish of material .
