Larry Crabb (EV2) has seen a need and has created the solution. BedWedgies. made from high-quality cast aluminum, these are the solution to your broken plastic bed rail slider ends on many models of Coleman and Fleetwood pop-up campers.
The Problem
The problem is an under-engineered plastic part from the original manufacturer.
Once the beds are extended and supports are installed, some of the weight of the bed (and its occupants) is transferred to the rail ends. The result is that the OEM rail end eventually fails. When it fails and eventually falls off, the aluminum bed rail end is then exposed and could snag or tear the canvas enclosure.
The Solution
Replace those broken and poorly-engineered plastic rail ends/wedges with the popupmods.com BedWedgies™!
BedWedgies™ are made in the USA from high-quality cast aluminum and come with a lifetime warranty! Replace those OEM plastic ends once and be finished with the job for good. The best part is that the cost of a set of OEM plastic ends which will likely fail again in the near future.
Why Buy?
The Problem
The Solution
Why Buy?
- OEM parts difficult to find and getting more difficult (and expensive)
- Replaces Coleman part 4754-4821 bed slide wedge
- Replaces Fleetwood part (info to come)
- Cheaper and easier than replacing the inferior OEM parts twice
- High-quality cast aluminum
- Made in the USA
- Lifetime warranty
