72c10
New Member
I'm open to suggestions, critique and scolding on this one. Mind you: I have no background in engineering, but had the safety of my family's and other motorists in mind when doing this. My biggest objective in this was to make it safe and secure, so my stuff doesn't go flying off on the roadway and pose a danger to us and especially anyone else behind me.
This is on an '07 StarCraft 1701.
So, we want to take our 5yo twins' kid bikes camping with us. If we tow with my wife's Durango, we'll have room, but if we take the Jeep Wrangler - nope.
I've been contemplating and planning all winter what I'd do. And, after carefully planning I came up with this...
I have a spare tire that is mounted on the back, which covered the bumper partially, but I wanted to get this bumper mounted hitch receiver.
As I took my spare tire cover off, I realized it only had 2 bolts holding it in, unlike my Jeep that had 3. This meant, if be able to rotate it. It worked when I tried it, as it would still allow the bed to slide out and cleared the bumper for the hitch receiver unit.
Now that it worked, I mounted the receiver and realized I was not comfortable with the security of the thin 1/8 bumper metall. So, I got a piece of steel that spanned the width of the inner bumper to serve as a giant washer for the mounting bolts and to distribute the weight/pressure to the span of the bumper.
After this, I mounted the sucker and it looked great. But, I wanted it more security. If I put a bike rack (don't have one) or out cargo hitch tray on it, the "pull" would be downward, so I thought of the top of the bumper. And saw two points on each side of the top of bumper where it is welded to the frame and saw that the top wasn't welded to the frame.
(Right side, looking from the top, left side is the same)
So, called a good friend that welded and he told me to head over. As I was simulating weight on the hitch receiver, I thought of something else... I thought I'd add support going from the bottom of the bumper, right where the receiver was mounted and welding 2 pieces of steel to the camper frame.
After mounting it all up, this is what it looked like.
I put the kidds' bike on it and then sat my 220lbs butt on it and the bumper flexed a bit... but, weirdly enough it was pretty secure. I added ratchet straps from the cargo tray frame, above the top of the bumper and attached it to the frame of the camper and it made it better. I may add braces on the top of the bumper and to the frame for added piece of mind later on when I have another few hours to spare.
And, if I don't like the set up after trying it, if I get sway (I shouldn't with the minimal weight) or I think it's to dangerous... It'll come off. But, I thought I'd give it a whirl.
All of this cost me about $50 in materialls, including the paint. Let me know your thoughts and experience. I couldn't find much on Google or YouTube for this, so I was on my own.
