StormFuel
- Aug 19, 2020
- 46
Hade the same issue with the front bunk on our 2017 2308ST. Had the latch and the entire slide replaced once under warranty as it happen in the middle of the night while my wife and I were in bed and it twisted the slide from the force when it popped. They put in the same style latch and guess what, on the second trip after repair same issue.View attachment 80592 I’ve got a 2019 Viking VTrek V3. This model has the bunk ends suspended from the roof via cables rather than supported from below with poles from the frame. One thing that happens to us on campouts is that the slides seem to wiggle past the latch that keeps them fully extended. It usually only happens on one of the slides and not both on each bed. Sometimes it happens if someone is on the bunk end tossing and turning. Other times it seems to happen at random. One thing that I find odd is that the latch is so small. I guess they did that so that it is easy to lift out to push the bunk ends in but it’s small enough that it’s inevitable that it will get loose at some point. Anyone seen this and have any suggestions?
Hi, thanks for your excellent solution! Would you happen to have a picture of the fix? We’re having the same issue?Hade the same issue with the front bunk on our 2017 2308ST. Had the latch and the entire slide replaced once under warranty as it happen in the middle of the night while my wife and I were in bed and it twisted the slide from the force when it popped. They put in the same style latch and guess what, on the second trip after repair same issue.
I removed the latch pin and replaced it with a long bolt that fits in the existing hole and goes all the way to the bottom of the track, a simple $2 fix. We completely remove the bolt and store it under the mattress when we close the trailer down. The only thing is you have to slightly pull beds out to remove the bolt but besides that no issue with this ever again!
I used almost the same fix as JFV.. I just use a cheap screwdriver holder with the bit removed. Works perfectly.View attachment 80592 I’ve got a 2019 Viking VTrek V3. This model has the bunk ends suspended from the roof via cables rather than supported from below with poles from the frame. One thing that happens to us on campouts is that the slides seem to wiggle past the latch that keeps them fully extended. It usually only happens on one of the slides and not both on each bed. Sometimes it happens if someone is on the bunk end tossing and turning. Other times it seems to happen at random. One thing that I find odd is that the latch is so small. I guess they did that so that it is easy to lift out to push the bunk ends in but it’s small enough that it’s inevitable that it will get loose at some point. Anyone seen this and have any suggestions?
