Here are some pictures of mineYea, my roadtrip does not have that option. The regulater is built into the controllers. So, if you xan take the regulater off your fuled burning appliance you are good, if not you will not get any btu output. So, it depends on the grill.
You know on my older StarCraft I cut the line in myself after the regulator to the low pressure side there is no reason you can't do that with the high pressure side is there and make your own connection point?Yea, my roadtrip does not have that option. The regulater is built into the controllers. So, if you xan take the regulater off your fuled burning appliance you are good, if not you will not get any btu output. So, it depends on the grill.
Michael J, where did you get that male quick connect adapter?
Off AmazonMichael J, where did you get that male quick connect adapter?
And somehow I ended up with extrasMichael J, where did you get that male quick connect adapter?
For future reference most of the Roadtrip grills can be converted to run off the low pressure quick connect. Most of them have a threaded regulator, and there are numerous adapters on Amazon that will replace the Coleman regulator with a quick connect.
I think there are actually 4 kinds of Road Trips that have been produced. I used to have one of the first - thebluemodel with a table/stand - this was the ideal one IMO. The stand had side wings to use as a worksurface, and the grill just sat on top of it. They could be stored apart, which made it much easier to pack in a pup. I would have had problems with the integrated ones they sell now as they are too high when folded up.
On mine the regulator used a spring clip pressure type fitting - no threads. I bought a spare regulator, removed the regulator portion, and triple clamped a propane hose to it. No leaks after several years of use.
The current ones use a threaded regulator, which is easy to get an adapter for.
They make another model that has stronger burners, but it is high pressure, so incompatible with the low pressure outlet most pups have.
Finally there is the model that has the regulator integrated with the knobs, so no chance of adapting.
I enjoyed cooking on mine - I had the 2 burner griddle, single burner cast iron grill grates, stove grates, and single burner griddles. However, after using it for a couple years, and then using a big Camp chef model with scouts I endded up selling the whole package. On mine it really struggled if there was any sort of breeze. I went so far as to pick up a stove Coleman made that was based on the Roadtrip, but had a flat lid with wind walls. It fit my model fine but I had to add some slots for the wind guards to clip into. That helped some, but wasn’t ideal. If you can block the wind, they are a great economical option. I coooked tons of food on mine over the years.
I now use a Camp Chef Pro60X that I rescued from the side of the road, along with a BBQ box that sits over one burner. I had to fix some bits, replace some knobs and bend the frame a little, but it is working great now. I even picked up a single burner griddle for it, and my outdoor coooking experience is approaching nirvana now. Very happy, although it weighs a fair amount. However, I don’t need to take the Weber anymore, and with alll the cast iron I had with the Coleman the whole thing is pretty close in weight anyway.
