Grey water ( sink ) Drainage issue
Bear&pop
New Member
Aug 11, 2023
Happy new owner of this Starcraft 3612. Instead of sink water draining to the tank, it just fills up the drain tube and then backs up into the sink. Maybe 2 gallons worth. There must be a valve but I can't find it. Any suggestions??
Thanks Steve and Jessica
Sneezer
3,121
I seem to recall that the Centinnial series had the sink and shower drains plumbed together. There should be an outlet under the pup with a valve. I think it is a 1-1/2” or 2” outlet. There is no tank for grey water, so you will need to come up with a solution. Many use buckets, aquatainers or a dedicatedd tote - I have a Rhino one myself.
Bear&pop
New Member
Aug 11, 2023
Thanks guys... I do have a gray water tank but it seems to service only the shower?? The sink drains only into the pipe running across the trailer with the cap. Seems strange.
Sneezer
3,121
Not really. A pup with a dedicated grey tank that the sink plumbs into is a huge rarity, if it even exists. If there is a tank for the shower, it is probably around 20 gal. Mine has a tank, shower only, and the sink drains to the side of the pup.
