levanceyschmancy
- Apr 5, 2022
- 27
gotcha - shoot - okay. Thank you so much for your help and not selling me something we can't handle. Also, this helps because I had no idea about the tongue weight max. So much to learn. I wish you the best in trying to find a buyer.It does not have a water heater. We heat water on the stove then pour the hot water into a shower kit to take warm showers in a shower tent.
I would like nothing better than to find a great family to sell my popup to, but I have to be the bearer of bad news. I tend to agree with the others that say your tow vehicle may be overmatched by a pup with a 10 foot box. I tow with a RAM 1500 and my popup even makes my RAM sag more than what I would like. The tongue weight of my popup would exceed your Ford Escape tongue weight capacity even if you are under the tow capacity.
Let me show you the math:
I see that the tongue weight capacity of the 2013 Ford Escape is 350 lbs. (10% of the tow capacity). The weight of my loaded pup is 2,603lbs.. The safe tongue weight of a trailer is 10%-15% of the total weight, making the tongue weight of my pup 260-390 lbs BEFORE the weight of the propane tank and the battery is added. The propane tank weighs around 40 lbs and the battery is around 55 lbs.
Therefor, the MINIMUM tongue weight of my popup is (260+40+55) 355lbs (already above your max). In reality, my tongue weight is probably closer to the maximum weight of (390+40+55) 485lbs. This, unfortunately, is well over your maximum tongue weight.![]()
