JoeCamper
Eastern, Pennsylvania
Hints for Using Your Cooler
For best performance, always pre-chill food and drinks.
Two six packs or one gallon of liquid will use approximately 2.5 lbs. of ice just to cool from room temperature. So plan ahead and cool off everything before you head out. You can even empty a few trays of ice into the cooler to pre-chill its interior.
Put the ice in last.
Cold air travels down, so if you want your beverage well chilled, load cans and bottles first, then cover with ice.
Do not store coolers in hot location.
When storing coolers, avoid hot places such as the garage or the trunk of a car. If this is unavoidable, bring the cooler inside at least 24 hours before use.
Keep cooler out of the sun.
Ice lasts up to twice as long when the cooler is in the shade.
Choose cube or block ice.
Use cube ice to quickly cool food and drink, block ice to keep it cold longer.
Dont drain cold water.
Recently melted ice keeps food and drinks cold. Melted ice water preserves ice better than empty air space.
Close lid quickly after opening.
Do not leave the lid open longer than necessary.
Use separate coolers.
Use one for beverages youll want frequently, another for the bulk of the food. The latter will keep ice longer because it will be open less frequently.
Protect perishable foods.
Place perishable foods like meat and dairy products directly on ice. Sealed plastic containers will keep food dry.
Use dry ice to keep food frozen.
Place the dry ice on top of the food. Be sure that the dry ice is wrapped in heavy layers of newspaper. Do not let dry ice come in direct contact with the interior liner or your hands.
Cleaning Your Cooler
Clean the inside and outside.
Clean the inside with a solution of mild soap and warm water, especially before first use. To remove tough stains, use baking soda and water to clean the inside.
Remove odors with a diluted solution of chlorine bleach and water.
If odor persists, wipe the interior with a cloth saturated with vanilla extract, then leave the cloth in the cooler overnight.
Always air-dry the cooler with the lid open before storing.
Turn the cooler on its end and open the lid to allow it to air dry. Avoid doing this in direct sun light as the excessive heat can damage the coolers insulation.
