LED lighting
BWR
Jun 25, 2022
I bought a 2006 Fleetwood Williamsburg popup, I would like to replace the lighting inside with LED, any suggestions would greatly be appreciated.
Thanks
Bradley
BWR
Jun 25, 2022
Yup, I did the same is every camper I’ve owned. I even changed the bulbs in the bunkend light/fan. That was fun.
Can you use the same fixture or did you place to accommodate the LED will a LED bulb fit into the existing fixtures.
Thanks
Bradley
jmkay1
2004 Fleetwood/Coleman Utah
8,062
I tried some cheap china brand LED lights from Amazon but they ended up burning out the same day I installed. So ended up driving to Auto zone and bought some led light bulbs there for my current fixtures. On your existing incandescent bulbs is a number I used that number to help me figure out the corresponding led bulb to use. Like popupsteve I even replaced my bunk end lights although discovered my bunkends lights used a different bulb then the rest of my light fixtures.
BWR
Jun 25, 2022
Thank you for taking time to help direct me in the way I need to go, not only you but all who gave me advice. I'm new to the popup world however I found a place to go when I need help. Again thank you all.
Bradley
xxxapache
4,606
I put cheap Chinese bulbs in my TT in 2017. I have not had to replace one. I have used the same or similar to replace all the 1156/1157 bulbs in my vehicles as needed. I haven't had one fail.
xxxapache
4,606
I recently needed a 194 bulb for a trailer marker light..A check with the autoparts store showed 2 incandescent bulbs to be about 5 bucks. I bought 50 LED bulbs from an eBay vendor for 11 bucks.
