Missing awning poles
Kevinwc67
Oct 12, 2022
Hi,
I have a Dometic Trim Line awning on my 2002 Starcraft 2107.
To my horror when I got the awning out on our 1st trip, I found that the awning is missing all 4 extendable poles which enable the awning to be put up 😢
My question is does anybody know where I can purchase these poles? Or where to get alternatives? I would also need the ball end from the poles into the connectors on the tent trailer?
The Dometic site seems pretty useless 😂
Raycfe
Waterford Ct.
18,439
So I am guessing you are looking for ends of the polesdometic-trim-line-bag-awning-product-id-944-parts-list
This may help. Over the years I have made tubes from EMT. It isn't expensive, but strong. I piece of 1/2 inch will fit inside a piece of 3/4. I use Velco as a bushing and slide. I am also guessing that the cups are for mounting the poles to the side of the camper. A simple L bracket and pin may also work. I also think that some people don't like the poles to the camper side because they walk into them.
Hope this helps.
Kevinwc67
Oct 12, 2022
Hope this helps.
Thank you for the suggestion. I found a replacement awning at half price ($250) at Hanna RV, so decided to go with a new one :) after all the one I have is probably the original one (20 years old) and the plastic awning material is pretty stiff now and probably doesn't have much life left :)
Kevinwc67
Oct 12, 2022
That’s very kind 🥹 but I have ordered a new awning now, but if there are any issues/delays with that then I will be in touch 👍 thank you so much 😊
