Outside tire wear
Mtlangst
230
Central, Illinois
I have a single axle trailer and on both tires the outside tread is worn smooth. I always (try) to run at max pressure. I have put a lot of miles on the tires. I try to run as light as I can but wonder if that is why the outsides of the tires are wearing. Would towing with the trailer closer to it’s gvwr “even” out the tires and have more even wear? Or is there something else causing this?
Anthony Hitchings
Gold Supporting Member
Mar 2, 2019
4,218
Oakland, California
does your axle have camber - or is it truly straight (when unloaded) ?
if it has camber, did someone truly flip it upside down for more clearance (and thus reverse the camber?)
are you running bias ply tires or radial tires
Sjm9911
12,947
How old are the tires, whats the weight range, and what do you think you have for weight on them? You could be right, running to light. Or too much rating on the tire for the weight.
Mtlangst
230
Central, Illinois
Camper specs:
Dry weight 1769
Ccc 883
Gvwr 2429
Recommemded tire
St185/80r/13/c
I have st185/80/13 load range D
I have weighed the camper and i am under the 883. And i have tried making sure I am light especially on long trips.
Age of tires:
Made on
12/18
They have over 40,000 miles on them easy.
Sjm9911
12,947
In this case, against everything I have always said on airing up to max inflation, I may put 5 to 10 pounds less in them.
Scratch that, 40 k miles. Lol. Better then some car tires. Count your blessings. But they might just be worn out. Get new skins and hope for the same results.
Jkoht
186
If it's the same wear on both sides I'd say you have an axle issue. Time to bring it to a shop to have someone look at it.
Could be wheel bearings. We peeled the tread off a tire, started on the inside, in 1000 km. Jacked camper up in campground and had a loose bearing. Changed to spare. Checked the other side, losse also. Bearings were ok just loose.
xxxapache
4,662
The OP's tires have wear on the outside. I would think loose wheel bearings wouldn't cause that.
brettstoner
153
Toledo, OH
Outside tire wear is typically caused by too much positive camber. Most trailer axles come with a little positive camber so when a load is on them the axle flattens out and has a very slight positive camber. A little positive camber helps the trailer track straight and reduce sway. I would replace the tires, check the wheel bearings, and take it to an alignment shop or trailer shop. They should get the axle camber 0 to 1/4 positive camber when fully loaded. They can rotate the axle (possibly) or bend it on a frame machine.
Now if you want a bit more redneck solution, remove the tires, pop the bead, reverse the tire, and remount. Trailer tires are pretty easy to spoon on and off. So now the outside will have the tread and can wear down.
Mtlangst
230
Central, Illinois
There actually is a trailer shop in my town so might see how much to check out everything for peace of mind. Although this year probably only doing one long trip due to gas prices (thanks Brandon).
Latest posts
