You may have seen posts about the PopUp Gizmos and wondered what they are exactly and what are the benefits.
The PopUp Gizmos (PUGS) is a multi-layered polyethylene cover for the tops of a camper’s bunkends. The main purpose of the PUGS is to reflect the radiant heat of the Sun, which keeps the temperature in the camper much lower. Anyone who has ever camped in an open field in the Summer can attest to just how hot it can get inside a camper. A set of PUGS can really help cut back on that heat. Even if the camper has A/C, a PUGS can help keep the A/C from running continuously. An additional benefit is that the PUGS will protect the vinyl and canvas tops from the UVs, rain, leaves, and bird droppings, keeping it looking like new longer. And the same PUGS will help to keep the camper warm in the Winter.
There are three styles of PUGS to choose from. The Standard, the Original High Wind, and the New Super High Wind. I have the Super High Wind PUGS and these are well worth the price difference. Easy to attach as the roof is being raised, the Super High Wind PUGS has five bungee cords on either side. These can be clipped to the exciting bungee under the bunkend or passed underneath to clip to each other. This secures the PUGS tightly to the bunkend as the bungees pass through ribs on the PUGS, holding it down on the top and eliminate ballooning. Take-down is just as easy and if needed, PUGS are washable. PUGS folds up flat, no bigger than a folded twin size bed sheet for easy storage.
One option that should also consider is to use Velcro to attach the PUGS to the inside of the roof. It makes setup even easer. With the Velcro option, just raise the roof about six inches, attach the PUGS and continue to raise the roof. The PUGS will hang down from the roof just like an awning. Now, when the buckends are pulled out, the PUGS will lie down on top of the bunkends. Once the shepperd's poles are installed, the PUGS can be secured to the bunkend. The Velcro option is extra for each PUGS.
There are only a few things that I feel I can’t do without while camping. PopUp Gizmos is one of them.
https://m.youtube.com/watch?v=-4uD9WUbGgI
Contact Info:
PopupGizmos
34 Green View Circle
Richardson, TX 75081
972-849-9240
http://www.popupgizmos.com
Contact Info:
PopupGizmos
972-849-9240
