My 2011 Jeep Liberty has a factory tow package with relatively small conductors from front to rear of the TV and only a 20A fuse in the +12V line to the 7-pin connector.
So the question was - what would happen if I try to use my 20A (rated output) Renogy DC-DC charger (which was bought 3 years ago, for a different reason)? Would it work at all, or would it blow the 20A fuse in theTV, or what?
The answer is:
1) Engine running at IDLE, 9.66V at the charger input, 13.6A going into the Li battery (battery was at 55% State of Charge).
2) Engine NOT running, start chargingat 8.81 amps into Li battery and 9.11 volts at charger input, but both declining steadily (not a realistic test).
3) repeated test (1) and got the same result.
DC-DC charger and the Li battery were outside the TV at the rear of it. This was a "lash-up" test using my 7-pin test harness.
So I do NOT NEED big wiring in my TV in order to get some useful charging when towing the camper - anything over 12A into the battery is OK for me because its likely a longish tow and the towing-charge is to supplement solar or what was left in the battery in the first place.
At age 72 I have no desire to run more wires in any car - so no wiring upgrade will happen. This arrangement works with all the standard wiring and fuses and relays etc in the Jeep - which is just fne.
Now I can focus on installing the DC-DC charger into the Aliner - it will be up front (inside) very close to the battery; along with the charge enable-disable switch.
Its fortunate that my DC-DC charger is the 20A model, I think that helped get a good result on a limited 12V suppply circuit circuit from the Jeep.
The answer is:
