the light gets power from the converter. it does not idicate the battery fuse is an issue.And if the fuse on the battery was blown , how would the light get power on the converter? Lol.
Thats what i am saying. If on battery power the light would still light right? If the power dosent gonthrough the battery fuse then thats good? Or does the battery power not light the light?the light gets power from the converter. it does not idicate the battery fuse is an issue.
The LED will illuminate on battery or Shore Power, all that the converter does is supply 12 volts (up to 14.4) onto the same connections as the battery. They basically work side by side.Thats what i am saying. If on battery power the light would still light right? If the power dosent gonthrough the battery fuse then thats good? Or does the battery power not light the light?
I know how it works. if they try it on battery power and the light illuminates then the fuse at the battery is good. Otherwise power would not get through to light the led in the converter.The LED will illuminate on battery or Shore Power, all that the converter does is supply 12 volts (up to 14.4) onto the same connections as the battery. They basically work side by side.
You sure it isnt that the two ends are touching ( in the picture) and when they put the fuse in its creating a arc and blowing the fuse? I would rule that out first. But otherwise, like I said see what the load is on the circuit.That red LED is simply an indicator that the fuse has blown, as others have mentioned. There are 4 red LEDs there, ea one corresponding to the 4 DC branch circuits 1 to 4.
You must have a dead short somewhere in circuit #1 to blow immediately like that.
On the cover of the converter will hopefully be a listing of what each breaker (120VAC circuit) corresponds to, and what ea fuse (12VDC) corresponds to.
If you can find out what is powered by that circuit (DC circuit#1), that would be a good first step.
That's right. SOmetimes they both blow and the light goes off. It's only on when the fuse at the battery is ok.And if the fuse on the battery was blown , how would the light get power on the converter? Lol.
RightI know how it works. if they try it on battery power and the light illuminates then the fuse at the battery is good. Otherwise power would not get through to light the led in the converter.
Thanks. We're going to Banff etc. for 2 weeks.Wiring on a pup can be confusing. Our Fleetwood is wired like house hold wiring even the 12v. The black which would be ground on an automobile is the hot lead on my pup. The white is ground. Not all pups have the same wire colors so not sure what wires Flagstaff uses. Glad you sorted out the problem, now get out there and go camping summers almost over
Now tag/mark/paint the cables so they will go on correctly the next time. The positive terminal wires going to the positive terminal should have be all the same color and a fuse or circuit breaker inline for protection. The feed wire for the breakaway switch usually is mounted directly to the battery.Hey!!! Thanks for all the advice and concern.
Problem solved. I took the battery off. Cleaned it thoroughly. It was a mess. Then When it came to putting it back on I tested the line that was attached to the positive. It showed a connection on my multimeter to the frame. The other one did not. So I remembered all the advice and realized that the cables were reversed. I put them on and wallaah. The power came on when I put a fuse in and it didn't short out. So, thank you. NMroamer gets the prize. But you all gave great advice and made me look at many things.
