I replaced my old Atwood mechanical thermostat in our 2013 Somerset Sun Valley with a Honeywell PRO 1000 Vertical Heat Non-Programmable Thermostat. I read and saw YouTube videos that showed this was an easy replacement. When I installed the thermostat, it was 99 degrees in the trailer. I had to wait for things to get below 89 (in the evening) today so that the thermostat could be set to 90 (the max) for testing. Upon doing so, the thermostat immediately turned the fan on (expected). I would hear the igniter clicking and then the thermostat would appear to reset - heat never came. This would keep happening. Gas was open and worked the other night (it was much cooler) with the Atwood thermostat.
During the install, I did have to reduce the wires a bit in order to fit into the mounts on the new thermostat - could that be the cause? The wires from the furnace are much thicker than a house thermostat will take, but they align w/ the connections (W and R). I merely removed strands - probably not the best way. Should I have used wire nuts with thiner wire to step down from the thermostat to the feed that drives to the furnace? Or is this just not meant to work? Or was it perhaps too hot out? Logically, I would never actually use a heater to warm up the trailer to this level.
I really don't want to order a replacement Atwood thermostat - they're junk. The off switches on them constantly get stuck (why I went to replace ours) and their temperature setting is comically bad.
