Trip report (Solar recap)
davido
1,545
I spent 4 days near Zion National Park over the long weekend.
I have a Renology 100w solar suitcase with built in Voyager 20A controller: This item
I also have a 25 foot solar extension cord set, and clips to attach the panel to my battery system.
The scenario: I was camped at about 6600 feet. Days were in the 78-80f range. Nights dropped to 40-45f.
Power requirements: Our energy budget is 25-32AH/day depending on how much the heater has to run (a lot less if the furnace doesn't run at all).
I have a dual-battery set up with two Group 24 batteries wired in parallel. That provides 160AH total capacity, 80AH usable before dropping to 50% charge.
With an energy budget of 30AH, approximately, I would drop below 50% on the 3rd day of the trip. But worse, I would worry all the time that I'm using more power than I think I am, forcing everyone to economize rather than just enjoying the trip.
Enter the solar panel: Using the extension cables I found a place where I could set the panel on the ground, where it wouldn't be affected by shade. This will be harder in a dense forest area. In Zion, it's pretty easy. I tilted the panel up, and changed its orientation so that in the morning it was pointing east, and then before leaving camp, I turned it to the west so that it could catch the afternoon sun more efficiently. Depending on sunlight conditions, the Voyager controller put out anywhere from 1.5A to 5.5A. During good sunlight times, it was always between 4.5A and 5.5A.
Every day the panel brought my battery bank to FULL. And the number of AH added was always over 30. When the controller detects that the batteries are full (and there are no significant loads), it shuts down to a trickle charge. So although it was giving me 30A per day, it would have provided more power if the batteries could have accepted more. On a sunny day with 8h of good sunlight, I would imagine you could get 40AH.
Keep in mind that in bad weather, you're only going to get 25% of that amount, so instead of, say, 35AH, you would only get 8-9AH.
So, a little paper napkin math. In good weather, with a daily usage of 30AH, a 100w panel brings me back to full every day. In bad weather, my 80AH of useful capacity will have 30AH drawn out of it per day, and 10AH replaced per day, with a net loss of 20AH. So in continual pessimal weather days, I could go about four days. Hopefully a typical camping trip won't be burdened with four days of straight rain. But if that were happening, we could get through it with our two-battery set up and single 100w panel.
In the end, I'm pretty happy with this solar kit.
davido
1,545
Sounds good. Besides the Heater, what are your power needs.
Furnace: 3A, 9h, 33% duty cycle = 9AH.
Water pump: 5A, 2% duty cycle (including showers, brushing teeth, etc): 2.5AH.
Cell phone charging (4 devices): 8AH
FanTastic Fan: 1.5A, 1.5h: 2.25AH.
Fridge vent fan: 0.25A, 20h: 5AH
Interior lights: .4A, 3h: 1.2AH.
Exterior porch light: 0.2A, 9h: 1.8A
Water heater solenoid: 1.2A at 5% duty cycle: 0.1A
Total: 29.85AH.
In practice I always saw the 100w panel's controller report about 32AH added per day, but that includes both topping off the battery, and running loads even after the battery has topped off, and trickle-charging. Assuming I can average 4.5A draw over 8h, I could get 36AH out of the panel per day. At Zion, it wouldn't be unreasonable to get 4.5A average over 10h, so 45AH as a sort of maximum (good sunlight from 8am to 6pm).
Obviously I could economize by running the furnace a little less, turning out the porch light, and plugging at least some of the phone devices into the tow vehicle, who's battery gets topped off every time I drive somewhere.
Econ
1,806
Deep South
Just as a suggestion, people may wish to comment on the degree tree coverage in the future on solar reports. We have seen videos of Zion so assume it is barren. Here the default is heavy tree coverage unless you are in a cow pasture.
PopUpSteve
Administrator
Staff member
Gold Supporting Member
Dec 22, 2002
22,079
Southeastern PA
Here some stats from this past weekend (Sunday morning), in the woods with good tree cover and the panels are flat on the camper's roof.
thumbnail_IMG_6634.png thumbnail_IMG_6637.jpg thumbnail_70706565585__D5FF483C-7A57-41A0-910D-93E064193416.jpg
This is from Monday afternoon in the parking lot of the storage yard.
davido
1,545
Nice. Where did you camp ?
East side of Zion; a friend owns camping property a few miles north of the east entrance, between the Cable Mountain trailhead, and the Observation Point trailhead, butting up against the Zion National Park fence.
Someone asked about the tree coverage: This side of Zion (the east side) has Ponderosa pines. In the area where I set up, I have to strategically place the panel so that it avoids tree shadows. But it's nothing like being in a dense forest. For dense forests, I would probably start by putting the panel on the roof, but even so, I would expect only an hour or two of sunlight.
davido
1,545
Good observation. Here's a picture looking east, fairly late in the day: 8:03pm, so the panel is fully shaded at this point.
gladecreekwy
1,905
Jackson Wyoming
We have 25’ of extension for ours. Pretty much guarantees finding sun. Not many trees where we camp
