Yeah, that's what the manual now says.
from https://battlebornbatteries.com/wp-...Manual-Edition.PIM_BB10012Rev010_06232022.pdf
Thanks for sharing your experience with it!That's a good path. I think if I had to do it over again, I would prefer having the direct switch method.
Yes, the swap is a "1-to-1" swap—even down to the cabinet hole size and screw holes.The swap went fine. I took my time. I separated all the ground wires, put ring terminals on them and connected them to a ground bus bar mounted within 8-10 inches from the back of the WFCO. I also installed a terminal block and fastened fork terminals to the wires and labeled the connections on the terminal block. (All the wires had been bundled under wire nuts.) Once I did this, removing and replacing the WFCO units was fairly straightforward. It certainly made matching the identical wires a cinch. Best thing—everything worked after I was done. The primary video I used as my initial reference was on this YouTube channel: https://www.youtube.com/watch?v=gxlWjzGLeb8&t=2s&ab_channel=TabTrailerUpgradesandMaintenance
Excellent video, thank you... I don't have an access panel overtop of the unit like he does, so getting at the wires thru the mounting hole of the unit itself seems to be one of my biggest challenges since I doubt the manufacturer left a generous amount of slack!!The swap went fine. I took my time. I separated all the ground wires, put ring terminals on them and connected them to a ground bus bar mounted within 8-10 inches from the back of the WFCO. I also installed a terminal block and fastened fork terminals to the wires and labeled the connections on the terminal block. (All the wires had been bundled under wire nuts.) Once I did this, removing and replacing the WFCO units was fairly straightforward. It certainly made matching the identical wires a cinch. Best thing—everything worked after I was done. The primary video I used as my initial reference was on this YouTube channel: https://www.youtube.com/watch?v=gxlWjzGLeb8&t=2s&ab_channel=TabTrailerUpgradesandMaintenance
You're welcome! I had the access panel above. That certainly made it easier. I've seen on other "swap" videos, one for a Progressive Dynamics unit PD-4135K, whereby there was no overhead panel. Here's one example: Meanwhile, good luck if you venture ahead, which of course will make it easier in the future to troubleshoot when you have an electrical problem.Excellent video, thank you... I don't have an access panel overtop of the unit like he does, so getting at the wires thru the mounting hole of the unit itself seems to be one of my biggest challenges since I doubt the manufacturer left a generous amount of slack!!
