I can’t locate a part number on it. So in 120v I need the heater element replacement to make that work.. . and when in propane I have no voltage going into the module, which means I can’t spark the pilot light. Wish I had a schematic to track things down. I’m two cunt hairs from yanking the fridge out and just installing a mini fridge.
Looks like a Dometic ? These are usually gas/ electric and expensive to replace also can be like gold dust to find second hand and silly prices...If you can get it repaired do it
My 2023 Rockwood 1940 has a 12 volt only compressor fridge. I think it’s an Everchill. You can probably get a new one of these for less than $400 as an option. I also bought a portable 12 volt compressor cooler for $200 on Amazon to add to my capacity and it can be used for other purposes. It’s about 35 liters capacity which is the same as my Igloo Wheelie Cool that is usually half full of ice. You can use it as a fridge or a freezer, but not both. It has a $20 off coupon right now. Nothing like a 35 degree beer on a hot day.
